Gateway 4
Mechanical
Always observe the operating environment information. If this environment is exceeded, it is likely that damage will occur to your Gateway 4.
- Height: 77.5mm
- Width: 150mm
- Depth: 66.2mm
- Weight: 0.8kg
- Operating Temperature: 0°C to 40°C
- Storage Temperature: -10°C to +50°C
- Operating Relative Humidity (max): 80% Non Condensing
- IP Rating: IP20 Indoor Use Only
