SimonH Posted September 3, 2019 Report Posted September 3, 2019 Hi, any chance someone could tell me in idiot terms the midi instructions to trigger GO in the main playback. Going to use CTRs Show control. Thanks Quote
Edward Z88 Posted September 3, 2019 Report Posted September 3, 2019 Hi Simon, There are 3 different MIDI Protocols FLX supports. These are MIDI Timecode (MTC), MIDI Show Control (MSC) and MIDI Notes. All three can be used to trigger cues on the Master Playback. The article below goes through each of these, and how they can be configured on FLX... http://support.zero88.com/990063141 Hope this helps, if you have any questions just let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
SimonH Posted September 6, 2019 Author Report Posted September 6, 2019 On 9/3/2019 at 5:21 PM, Edward- Z88 said: Hi Simon, There are 3 different MIDI Protocols FLX supports. These are MIDI Timecode (MTC), MIDI Show Control (MSC) and MIDI Notes. All three can be used to trigger cues on the Master Playback. The article below goes through each of these, and how they can be configured on FLX... http://support.zero88.com/990063141 Hope this helps, if you have any questions just let me know. Edward so my software can do basic MIDI channel messages (Note On, Program Change etc) but not MIDI Show Control so is it possible with these to just trigger a GO on the main playback? Quote
Edward Z88 Posted September 6, 2019 Report Posted September 6, 2019 Hi Simon, With MIDI Notes, each individual Note command triggers each individual cue. For example when the console is set to Notes triggering Cues, and it receives a MIDI Note On 10 command, the console will trigger cue 10 in the currently viewed playback. If you wanted to simply emulate a Go button press with the same MIDI Note command, you could do this, however via programming a Macro. Firstly, program a macro that presses your Go button. You can do this by tapping RECORD MACRO x ENTER (where x is an empty macro number) -> Keys -> Press your Playback's Go button -> MACRO. Now, view an empty playback, and program an empty cue. Go into this cue's settings -> Macros... -> Macro Add -> Choose your Macro -> OK -> OK. Now, whenever you send a MIDI Note 1 command and you are viewing this single cue macro playback, it will emulate a Go button press of your main cue stack. Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted September 6, 2019 Report Posted September 6, 2019 Hi Edward, Can you please update the KB article with this - or at least equivalent - detailed information. I was interested in the process so had a read of the KB you quoted. The article really is lightweight in this respect as clearly from your replies on this thread there is more to setting up MIDI triggers than the article implies. The article simply says "MIDI Notes cause a Go to the cue corresponding to the Note-On message on the currently viewed/selected playback. Programmed Fade times are used, and velocity information is ignored." From your explanation above, it's quite clear the process is much more involved and requires MACROs - MACRO is not mentioned anywhere in the KB. Thanks, Kevin Quote
Edward Z88 Posted September 6, 2019 Report Posted September 6, 2019 Hi Kevin, Macros are only required if you want a single Note command to emulate a Go button press. In most uses of MIDI Notes as the article describes, the Note number you send to the console, will trigger that cue number on the viewed playback. I will however add this information as a tip under the Note's Cues section. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Edward Z88 Posted September 6, 2019 Report Posted September 6, 2019 Article updated, let me know if there's anything else you feel would be beneficial... http://support.zero88.com/990063141 Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
SimonH Posted September 6, 2019 Author Report Posted September 6, 2019 exactly what I needed thank you! Quote
Edward Z88 Posted September 6, 2019 Report Posted September 6, 2019 19 minutes ago, SimonH said: exactly what I needed thank you! Great! If you have any questions just let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
SimonH Posted September 10, 2019 Author Report Posted September 10, 2019 is there a way, using remote, that I can view the cue list of the main playback whilst the desk is in the macro playback? Quote
Edward Z88 Posted September 10, 2019 Report Posted September 10, 2019 Hi Simon, 2 hours ago, SimonH said: is there a way, using remote, that I can view the cue list of the main playback whilst the desk is in the macro playback? On FLX consoles, only one playback can be viewed at a time, so in your set up for the MIDI Notes to work you will need to be viewing the macro playback. By viewing, this means the playback has been chosen by holding VIEW and tapping the playback's button, so that it is brought into the cue list window. You can then continue to use the other desktops. If you would like to remotely see what cue you're in, you could move your main playback to an empty playback on the multi-function faders. You could then remotely view the Faders desktop, which indicates the current and next cue number for each playback. You would need to re-record your macro with the new playback go button if you wished to do this. Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Delete-0-Enter Posted September 23, 2019 Report Posted September 23, 2019 (edited) On 9/6/2019 at 10:23 AM, Edward- Z88 said: For example when the console is set to Notes triggering Cues, and it receives a MIDI Note On 10 command, the console will trigger cue 10 in the currently viewed playback. Hi Edward, we can't trigger point cues using that method, right? ( I know they can be triggered with MIDI Show Control. ) So I can either renumber my memories so point cues I made earlier get transformed to integers or use the single note command via Macro, correct? Including this info in the KB article could also be helpful to users. Edited September 23, 2019 by Delete-0-Enter Clarity Quote
Edward Z88 Posted September 25, 2019 Report Posted September 25, 2019 Hello, On 9/23/2019 at 8:38 PM, Delete-0-Enter said: we can't trigger point cues using that method, right? That's correct. The MIDI Notes standard only allows for whole note numbers. On 9/23/2019 at 8:38 PM, Delete-0-Enter said: So I can either renumber my memories so point cues I made earlier get transformed to integers or use the single note command via Macro, correct? Including this info in the KB article could also be helpful to users. Correct. Thank you - knowledgebase article updated. All the best, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Delete-0-Enter Posted September 25, 2019 Report Posted September 25, 2019 That's great, thanks Edward! Quote
TimC Posted August 13, 2022 Report Posted August 13, 2022 On 9/6/2019 at 10:09 AM, Edward Z88 said: Article updated, let me know if there's anything else you feel would be beneficial... http://support.zero88.com Edward Edward I would like to view this article but the link dpesnt work for me. When I go to zero88 support the address is https://zero88.com/support Quote
Davidmk Posted August 14, 2022 Report Posted August 14, 2022 Pretty much all the KB articles have been incorporated into the manual here. I suggest you select the correct console version and search for MIDI as the information you require may be under mode than one heading. Quote
Edward Z88 Posted August 14, 2022 Report Posted August 14, 2022 Hi @TimC 20 hours ago, TimC said: Edward I would like to view this article but the link dpesnt work for me. When I go to zero88 support the address is https://zero88.com/support As @Davidmk mentions, all of the ZerOS articles on the knowledge base site have been migrated to their relevant section of the ZerOS online manual. The MIDI Notes section is available here… https://zero88.com/manuals/zeros/setup/triggers/midi-notes Hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
