MIDI Notes - ZerOS | Zero 88
Triggers
MIDI Notes
A MIDI signal can be connected to your console using 5 pin DIN connectors, inserted into the MIDI Input port. There is also a MIDI Thru port, which can be used for daisy chaining other MIDI devices in your system. ZerOS does not support MIDI over USB protocols, and therefore to connect to software packages you may need a USB to MIDI interface box.
The Zero 88 team use the MOTU FastLane USB MIDI interface for testing and demonstrations using QLab.
Setuptriggersmidinotes
ZerOS supports the MIDI Notes protocol input. In the Triggers tab of Setup, you can define whether these Note commands trigger Channels, Cues or Playbacks.
After choosing Channels, Cues or Playbacks, select the MIDI Notes Channel number. This is essentially your console's MIDI address, so that if you have multiple devices listening to a MIDI Notes source, your console can be unique.
You can then use a MIDI Notes source, to send a Note Number, and that Note's velocity. MIDI Notes sources could be a software package running on a computer (with an appropriate USB to MIDI interface), or could be a MIDI button bank, or MIDI keyboard.
Channels
MIDI Notes information controls channel levels which are mixed HTP with the channel outputs. Velocity information from the Note-On commands is used to determine the fade up time, and velocity information from the Note-Off commands is used to determine the fade down time. The Note Number controls the console fixture number. A Velocity of 0 will not trigger the channel. A velocity of 1 will give a 5 second fade time to full, and as the velocity is increased, this will shorten the fade time, until you reach a velocity of 127 which will Snap.
Cues
A MIDI Note On command, will trigger the same cue number as the note number. For example a MIDI Note On of Note Number 10, will trigger cue 10. The playback used is the currently viewed/selected playback. Programmed Fade times are used, and velocity information is ignored.
MIDI Notes only allows for whole note numbers. Therefore if you have point cues you wish to trigger, you will need to renumber the cues in the playback. To do this hold SETUP and tap the playback's button, and from the settings choose Advanced -> Renumber.
Playbacks
MIDI Notes controls playback levels which are mixed HTP with physical fader positions to control the level of the playback. Velocity information from the Note-On messages is used to determine the fade up time, and velocity information from the Note-Off commands is used to determine the fade down time. MIDI Note 0, will trigger playback 1, and so on. Notes are therefore mapped 0:1 with playbacks. Velocity of 0 will not trigger the playback. A velocity of 1 will give a 5 second fade time to full, and as the velocity is increased, this will shorten the fade time, until you reach a velocity of 127 which will Snap.
