SimonH
Midi trigger of main playback
any chance someone could tell me in idiot terms the midi instructions to trigger GO in the main playback. Going to use CTRs Show control.
Thanks
Hi Simon,
There are 3 different MIDI Protocols FLX supports. These are MIDI Timecode (MTC), MIDI Show Control (MSC) and MIDI Notes. All three can be used to trigger cues on the Master Playback. The article below goes through each of these, and how they can be configured on FLX...
http://support.zero88.com/990063141
Hope this helps, if you have any questions just let me know.
On 9/3/2019 at 5:21 PM, Edward- Z88 said:
Hi Simon,
so my software can do basic MIDI channel messages (Note On, Program Change etc) but not MIDI Show Control so is it possible with these to just trigger a GO on the main playback?
Hi Simon,
With MIDI Notes, each individual Note command triggers each individual cue. For example when the console is set to Notes triggering Cues, and it receives a MIDI Note On 10 command, the console will trigger cue 10 in the currently viewed playback.
If you wanted to simply emulate a Go button press with the same MIDI Note command, you could do this, however via programming a Macro.
Firstly, program a macro that presses your Go button. You can do this by tapping RECORD MACRO x ENTER (where x is an empty macro number) -> Keys -> Press your Playback's Go button -> MACRO. Now, view an empty playback, and program an empty cue. Go into this cue's settings -> Macros... -> Macro Add -> Choose your Macro -> OK -> OK. Now, whenever you send a MIDI Note 1 command and you are viewing this single cue macro playback, it will emulate a Go button press of your main cue stack.
Hi Edward,
Can you please update the KB article with this - or at least equivalent - detailed information. I was interested in the process so had a read of the KB you quoted. The article really is lightweight in this respect as clearly from your replies on this thread there is more to setting up MIDI triggers than the article implies. The article simply says "MIDI Notes cause a Go to the cue corresponding to the Note-On message on the currently viewed/selected playback. Programmed Fade times are used, and velocity information is ignored." From your explanation above, it's quite clear the process is much more involved and requires MACROs - MACRO is not mentioned anywhere in the KB.
Thanks, Kevin
Hi Kevin,
Macros are only required if you want a single Note command to emulate a Go button press. In most uses of MIDI Notes as the article describes, the Note number you send to the console, will trigger that cue number on the viewed playback.
I will however add this information as a tip under the Note's Cues section.
Hi Simon,
2 hours ago, SimonH said:
is there a way, using remote, that I can view the cue list of the main playback whilst the desk is in the macro playback?
On FLX consoles, only one playback can be viewed at a time, so in your set up for the MIDI Notes to work you will need to be viewing the macro playback. By viewing, this means the playback has been chosen by holding VIEW and tapping the playback's button, so that it is brought into the cue list window. You can then continue to use the other desktops.
If you would like to remotely see what cue you're in, you could move your main playback to an empty playback on the multi-function faders. You could then remotely view the Faders desktop, which indicates the current and next cue number for each playback. You would need to re-record your macro with the new playback go button if you wished to do this.
Hope this helps,
