Simonkbike Posted June 11, 2022 Report Posted June 11, 2022 Getting error messages on boot so looks like I need to replace the battery. I found this topic in Orb section Battery Replacement which seems to have a good suggestion. Can't find if it's been actioned or do we still need to email support? NB - my old iPad won't display the Solution drawing .DWG file from website - maybe a PDF version? Cheers S Quote
kgallen Posted June 11, 2022 Report Posted June 11, 2022 It’s probably a CR2032 or similar coin cell? It you feel competent to do the job the go ahead. What is worth researching is which screws to remove to get access as usually it’s not all of them (for example on Frog desks it’s just two screws required to be removed not all 20). Quote
Jon Hole Posted June 11, 2022 Report Posted June 11, 2022 For screws: ORB: https://zero88.com/storage/downloads/c1fe1a80-25f9-4155-9d01-31c241a10ac8/orb-access-diagram.pdf ORB XF: https://zero88.com/storage/downloads/f6bb58da-c63a-41dd-b467-efb049a85503/orb-xf-access-diagram.pdf (These are both available from the ORB Product Page: https://zero88.com/control/orb) Once you're inside, you should easily see the CR2032 battery on the main processor board (the board screwed to the bottom of the console) 1 Quote Jon Hole linkedin.com/in/jonhole
kgallen Posted June 11, 2022 Report Posted June 11, 2022 2 hours ago, Jon Hole said: For screws: ORB: https://zero88.com/storage/downloads/c1fe1a80-25f9-4155-9d01-31c241a10ac8/orb-access-diagram.pdf ORB XF: https://zero88.com/storage/downloads/f6bb58da-c63a-41dd-b467-efb049a85503/orb-xf-access-diagram.pdf (These are both available from the ORB Product Page: https://zero88.com/control/orb) Once you're inside, you should easily see the CR2032 battery on the main processor board (the board screwed to the bottom of the console) Jon I think the guy has a Solution rather than Orb, but couldn’t open the DWG file for Solution. I could be wrong, sorry if so. Quote
Edward Z88 Posted June 11, 2022 Report Posted June 11, 2022 Hi @Simonkbike On 6/11/2022 at 10:51 AM, Simonkbike said: Getting error messages on boot so looks like I need to replace the battery. If you are receiving a “Non-Volatile RAM” error, this indicates the battery needs replacing. To open the console, remove the screws in the diagram below.. https://zero88.com/storage/downloads/6c4dcd75-9f3b-4a1f-a33d-371491b2c707/Leafrog-Solution-Access-Diagram.PDF The front panel can then hinge away from the base - be careful not to tug any ribbon cables. The CR2032 coin cell can then be replaced. Do feel free to email support@zero88.com if you need assistance. Hope this helps, Edward 1 Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Jon Hole Posted June 13, 2022 Report Posted June 13, 2022 On 6/11/2022 at 5:26 PM, kgallen said: Jon I think the guy has a Solution rather than Orb, but couldn’t open the DWG file for Solution. I could be wrong, sorry if so. Apologies, you're completely correct - I was on my mobile and didn't notice that minor (!) detail. As usual, ignore me and read what Edward says 🙂 1 Quote Jon Hole linkedin.com/in/jonhole
