ZerOS Library files (.zlbr) contain fixtures in the new library format, which cannot be edited. These fixtures are created as per the fixture's official manual in our format. If you wish to customise fixtures, individual .ift files can be downloaded from the link below...
https://zero88.com/fixtures/legacy-library/Legacy library (gft41.0)/
I hope this helps, if you have any questions let me know.
  • 3 weeks later...
so the old fixtures I created are no longer compatible? do we have to use the official versions?
there is no update for fixture creator?
Fixture files in the .ift format, are still compatible with the latest versions of ZerOS. You can continue to use these fixtures without issue, rather than using the fixtures contained in the library. To get any missing fixtures added to a future fixture library release, drop us an email to fixturesupport@zero88.com, with a link to the fixture's manual.
5 hours ago, Edward- Z88 said:
Why are my fixtures in red? what is the manipulation I have to do? on the console or on the fixture creator software
Fixtures displayed in red in the Fixture Schedule and Add Fixtures, are fixtures that are not from the ZerOS fixture library. Instead, these fixtures are from other sources, and will not follow the same standard format as library fixtures. The Fixture Schedule gives the ability to convert these fixtures to their library version, if this fixture model and mode is included in the ZerOS Library. You don't have to convert the fixtures to the library format, and can continue to use them as usual.
For more information on converting fixtures, see the link below...
https://zero88.com/manuals/zeros/patching/fixture-schedule/change-fixture#convert
