Hello
I'm coming for a other French user.
So he had connect a other DMX console, in the "DMX In" and he want to record in memories. things from Jester console and the other console...
1/ So is it possible to recording DMX Data from a external console ?
2/ There is special things to do ?
3/ If it's possible what are the memories limits ?
Thank for your help and this French user
Eric
Just a other question about "DMX IN"
Jester Fader use for exemple channels 1 to 48. A other console in DMX in use 49 to 96. So the Jester quand record Chanels 1 to 96 ?
Hi Eric,
That is correct. If you connect another lighting console into the DMX input of the Jester, you can store the DMX input state into a memory or submaster on Jester.
See page 20 of the manual for more information...
https://zero88.com/storage/downloads/7d3249f0-bde3-471d-8830-d4253ff0dc06/Jester-Manual-3.4.pdf
Hope this helps,
Last question about Jester Manuel 3.4, and last OS version 4.1 ...
News things about Manual between Jester OS ?
Thanks Edward.
I transmitted this information
Thank a lot
Hi Eric,
When you store a scene, all 512 incoming DMX channels, and the Jester's current channels, are stored.
If the other DMX console is outputting channels 49-96, and you store this to a memory or submaster, you will store a scene where 1 to 48 are the Jester's levels, 49-96 are the incoming levels, and 97-512 are at 0.
News things about Manual and Jester OS ?
Jester manual v3.4 is correct as per JesterOS 4.1, which is the latest software for Jester consoles.
Hope this helps,
