Edward Z88 Posted December 11, 2019 Report Posted December 11, 2019 Dear All, Zero 88 Fixture Library version 39 has now been released. For full information, including a list of included fixtures, please visit: http://zero88.com/library This release contains 11,461 fixtures from 379 different manufacturers. The library is released in 2 formats: Full version for desks running ZerOS software (FLX, FLX S, Solution range, ORB range and Leap Frog 48 & 96). Filtered version for other Zero 88 desks. This removes data that is not used by these other desks, so that the file is smaller. When using a floppy disk (original Frog series, Illusion 500) it is recommended that the floppy disk be freshly formatted before using it. Download & Installation The correct format of the library for your desk can be downloaded by clicking the product name below. Please ensure your console is running the latest software before attempting to update. The library (.ift file) should be placed in the root directory of the floppy disk or USB stick. ZerOS desks (FLX, FLX S, Solution range, ORB range and Leap Frog 48 & 96)To load this file into your console extract it to the root of a USB stick and plug into your console. Then tap SETUP, tap "Load", then select the GFT.ift file. JesterML & JesterTLTo load this file into your console extract it to the root of a USB stick and plug into your console. Then tap Setup -> Update Fixture Lib -> Update Library. If the update fails, click here for more information. Frog Series and Illusion 500Use 'Common Fixture Manager' (included in the Fixture Tools download) to select the fixtures you wish to use, and save this as a file to a floppy disk. DiabloThe fixture library is used with the Diablo Fixture Manager PC software. Sirius 250/500Use the Fixture Type Editor to import fixture types from the fixture library, and then use the ‘Export Sirius UFT’ function (under the ‘File’ menu) to generate data in the correct format for the Sirius 250/500. Further details of assigning fixtures on the desk to fixture types in the fixture library can be found in each desk’s operating manual. Additional FixturesIf you need a fixture type which is not in the library, please click here. Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
