Hi Thymen,
The latest manual for Solution consoles is correct as per ZerOS 7.9.2, available here...
https://zero88.com/control/solution#downloads
The FLX series manual available here is correct as per ZerOS 7.9.6...
https://zero88.com/control/flx#downloads
As FLX runs the same software as Solution, you will find the majority of the functionality described in the manual can be applied for Solution.
Hope this helps, if you have any questions let us know.
