Jon Hole Posted July 19, 2019 Report Posted July 19, 2019 Dear All, Zero 88 Fixture Library version 38 has now been released. For full information, please visit: http://zero88.com/software/library This release contains 10380 fixtures from 360 different manufacturers. For a list of fixtures in the library please click here. The library is released in 2 formats: Full version for desks running ZerOS software (ORB Series, Solution series, FLX Series, and Leap Frog 48 & 96). Filtered version for other Zero 88 desks. This removes data that is not used by these other desks, so that the file is smaller. When using a floppy disk (original Frog series, Illusion 500) it is recommended that the floppy disk be freshly formatted before using it. Download & Installation The correct format of the library for your desk can be downloaded by clicking the product name below. The library (.ift file) should be placed in the root directory of the floppy disk or USB stick. ZerOS desks (FLX, FLX S, ORB Series, Solution series and Leap Frog 48 & 96)To load this file into your console extract it to the root of a USB stick and plug into your console. Then tap SETUP, tap "Load File", then select the GFT.ift file. FROG2To load this file into your console extract it to the root of a USB stick and plug into your console. Then tap SETUP, tap "Load File", then select the GFT.ift file. JesterML & JesterTLThe fixture library is installed on the desk at manufacture, however this can be updated from USB if required in Setup -> Update Fixture Lib -> Update Library. Frog Series and Illusion 500Use 'Common Fixture Manager' (included in the Fixture Tools download) to select the fixtures you wish to use, and save this as a file to a floppy disk. DiabloThe fixture library is used with the Diablo Fixture Manager PC software. Sirius 250/500Use the Fixture Type Editor to import fixture types from the fixture library, and then use the ‘Export Sirius UFT’ function (under the ‘File’ menu) to generate data in the correct format for the Sirius 250/500. Further details of assigning fixtures on the desk to fixture types in the fixture library can be found in each desk’s operating manual. Additional Fixtures If you need a fixture type which is not in the library, please read the following thread: Quote Jon Hole linkedin.com/in/jonhole
James Herbert Posted December 4, 2019 Report Posted December 4, 2019 Hi, when trying to download https://zero88.com/forum/files/file/8-fixture-library-full/ ,I get Sorry, there is a problem The page you requested does not exist Error code: 1S160/2 Quote
Edward Z88 Posted December 4, 2019 Report Posted December 4, 2019 Hi James, We have recently launched a new Zero 88 Website, which we have migrated the fixture library download over to. The Fixture Library download for ZerOS consoles is available here... https://zero88.com/library#zeros If you have any questions let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
