Afx,
Did you know you can create your own fixture definitions using this Windows tool? Much quicker if you are in a hurry - you can always get the Zero88 guys to build a "proper" one and then you can compare-and-contrast theirs to yours so you can learn the "standard" way.
https://zero88.com/library#tools
Edward,
It would be good to have a KB article on the key points for building a standard fixture definition - like which Special to select, what to name Colour Wheels ("Color1"), what the defaults for RGBWAUV should be (ie R=G=B=255, others=0) etc etc. Even just a list would be a good reference. Also tips like handling fixtures with multiple "lamps", like the Combi Spot you built for me the other month which had wash and spot elements, where you used a virtual dimmer to scale the separate fixture dimmers under beamshape for wash and spot.
Ill shoot this to mail very shortly. In case of emergency, I can run this with Dimmer as fx and leds as separate but would prefer a real profile. I know of the fixture builder but dont have time before this gig. Gotta get to know it later on.
