Afx Posted July 2, 2019 Report Posted July 2, 2019 I`d need this for thursday If possible. Sorry for timetable. https://www.manualslib.com/manual/1007741/Eurolite-Nsf-350.html Quote
Edward Z88 Posted July 2, 2019 Report Posted July 2, 2019 Hello, Please drop us an email to FixtureSupport@zero88.com with this request, and the team will be able to create this for you. We will do our best to get this to you for Thursday. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted July 2, 2019 Report Posted July 2, 2019 Afx, Did you know you can create your own fixture definitions using this Windows tool? Much quicker if you are in a hurry - you can always get the Zero88 guys to build a "proper" one and then you can compare-and-contrast theirs to yours so you can learn the "standard" way. https://zero88.com/library#tools Edward, It would be good to have a KB article on the key points for building a standard fixture definition - like which Special to select, what to name Colour Wheels ("Color1"), what the defaults for RGBWAUV should be (ie R=G=B=255, others=0) etc etc. Even just a list would be a good reference. Also tips like handling fixtures with multiple "lamps", like the Combi Spot you built for me the other month which had wash and spot elements, where you used a virtual dimmer to scale the separate fixture dimmers under beamshape for wash and spot. Quote
Afx Posted July 2, 2019 Author Report Posted July 2, 2019 Ill shoot this to mail very shortly. In case of emergency, I can run this with Dimmer as fx and leds as separate but would prefer a real profile. I know of the fixture builder but dont have time before this gig. Gotta get to know it later on. Quote
