kgallen Posted October 18, 2017 Report Posted October 18, 2017 Here are profiles for: Cameo LED MiniPAR COB 30W Stairville Mini Stage PAR 4x8W RGBA Regards, Kevin cameo_cob30_stairville_miniRGBA.ift Quote
Edward Z88 Posted October 19, 2017 Report Posted October 19, 2017 Hi Kevin, Thank you for those, will add them to the library to be included in GFT release version 35. In future feel free to send fixture files you've created to FixtureSupport@zero88.com and we'll add them to the library. Cheers! Kind regards Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted October 19, 2017 Author Report Posted October 19, 2017 Thanks Ed. I tend to post them here then if other users need them, they know they are available. In the Stairville, I've decoded all of the preset colours into the Detail tab. These aren't documented in the manual so I had to work them out by comparing with a Lee gel swatch book. Please check the fixture names are in accordance with Zero88 style - sometimes I'm not sure how to name these things and how to derive the short name. Thanks! Kevin Quote
Edward Z88 Posted October 19, 2017 Report Posted October 19, 2017 Hi Kevin, That's great thank you. Yes they work with the style. I'm sure you've already seen this but if not/for others attached is the Fixture Editor User Guide that talks about how to name parameters etc. For the long name, use the Fixture's model followed by a space, then colon, then another space, and then the Mode name. If no specific Mode name then just put the channel count. For the short name, type in as longer name as you can including the mode information within the character limit! Kind regards Edward Fixture Editor User Guide.pdf Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
