bronson Posted July 22, 2024 Report Posted July 22, 2024 FLX24 S Hi, I always used a wireless DMX sytem on my console. Never had any special problems but since the 7.14.1 upgrade the transmitter suddenly indicates 'no dmx'. I did try everything from exchanging transmitters/receivers cables etc. but no solution. It happens like 10 times during a show. Could it be possible that there was a adjustment in the signal power strenght for the DMX output? Quote
Edward Z88 Posted July 25, 2024 Report Posted July 25, 2024 Hello, I'd recommend updating your console's software to ZerOS 7.14.3. The latest software is ZerOS 7.14.3, which can be downloaded from the link below… https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/ZerOS-7.14.3.exe Release notes listing software changes can be found on the ZerOS webpage… https://www.vari-lite.com/global/products/zeros-software Software updates completely wipe your console, so make sure you save a copy of your show file to a USB drive first if you need it. For information on saving your show file, please see the link below… https://zero88.com/manuals/zeros/setup/save Once you have backed up your show file, installation instructions can be found here… https://zero88.com/manuals/zeros/setup/load/zeros-software Once installed, you will be able to load your show file back into the console from a USB drive. For more information, please see the link below… https://zero88.com/manuals/zeros/setup/load/zeros-show-files I hope this information is helpful. If you have any questions regarding the software installation process, please let us know. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Mrdjjag Posted August 12, 2024 Report Posted August 12, 2024 On 7/22/2024 at 10:24 AM, bronson said: FLX24 S Hi, I always used a wireless DMX sytem on my console. Never had any special problems but since the 7.14.1 upgrade the transmitter suddenly indicates 'no dmx'. I did try everything from exchanging transmitters/receivers cables etc. but no solution. It happens like 10 times during a show. Could it be possible that there was a adjustment in the signal power strenght for the DMX output? Expand Same problem for me, for me it interupted the dmxsignal with a gap every like 4-5 sec long enough for the wirelessdmx to lose signal. I ended up buy an artnetbox to dmx and used the internet port, only there the interupted signal dident accure. So the problem seam to be trough the dmx port since the 14.1 update Quote
