Remote Switches - ZerOS | Zero 88
Triggers
Remote Switches
There are 8 close-contact remote switches available. These can be wired in and configured to trigger either a specific cue or a macro when the circuit is made.
Setuptriggersremote
For each switch, choose between Disabled, Go to Cue, or Macro.
For Go to Cue, you can then type x/y, where x is the playback number and y is the cue number. Cue 0 of a playback can be triggered as a way to release it.
Remoteconnector
A 9 pin D-sub connector providing 8 remote switches (common ground) can be found on the rear of the console. Short pin 1-8 to pin 9 (common) to simulate a button push.
