Fixture Schedule
Fixture Names
By default, fixtures are named using their fixture type (eg “LED Unit”). However they can be renamed to provide more useful information. For example, you may label them “Stage Left LED Unit”, “Centre Stage LED unit”, “Stage Right LED Unit” or "Movers".
To rename a fixture, tap on it in the "Name" column. To rename multiple fixtures, select them, and tap the column header button labelled "Change All Names" at the top.
Fixture names are shown in the Output Window (pictured), along with the MFF Window. This allows you to see exactly what each channel fader is controlling.
When sequential names are identical, the name is only displayed once per row in the Output window. A vertical line splits up fixtures with different names.
