Deleting Fixtures - ZerOS | Zero 88
Fixture Schedule
Deleting Fixtures
Are You Sure You Want To Delete Fixtures
Deleting fixtures is a permanent change to the show file and should not be carried out without intention. There is no undo function, so exercise caution when using this function. To delete a fixture, select the fixtures using the MFF channel buttons, or use the Patch Groups along the bottom of the fixture schedule, and then press the Delete button on the front panel. The desk will ask you to confirm the deletion and then remove the fixtures from the show file. This includes modifying all cues, groups and palettes to remove all references to this fixture. This action cannot be undone.
