Output Window | Zero 88
Desktops & Windows
Output Window
The Output Window is arguably the core window that can be viewed in ZerOS. The Output Window will show you your patched fixtures in fixture/channel number order. The fixture number is displayed in white, with their current intensity percentage displayed below.
The shortcut to view the Output Window on consoles without a monitor, is by holding Shift and pressing View.
If you have an external monitor connected, the Output window is shown on the top half of both the Cues and Faders desktops:
Output Window
Outputcolours
Intensity Information
The intensity percentages of your lights are displayed in various colours, which indicate the following:
  • Red - Programmer Data
  • Yellow - Highlight/RemDim active, UDK Channel Data, HTP channel data, or Intensity defaulted to above 0%.
  • Blue - Playback data
  • Green - Value faded down in a cue
  • Purple - Tracked Value
  • White - Blocked Value
  • Red Background - Parked
  • Grey Background - Moved On Dark
  • Line above value - A Topset/Max Level is active
For more information on what these various values are, go to their relevant section of the manual.
Outputselection
Selection
When the channel is selected, the LED in the button under the fader will turn on, and an orange box will be drawn around the channel number in the Output Window.
Grey outlines around rows of fixture numbers in the Output Window indicate which set of fixtures are currently being controlled by the channel faders.
Outputsource
Intensities / Source buttons
The “source” button displays what’s in control of each fixture. The following descriptions are used:
  • C 1/1 - Playback 1, Cue 1
  • C 22/5 - Playback 22, Cue 5
  • UDK 1/1 - UDK Page 1, UDK 1
  • P - Programmer
  • D - Default value
Pressing “Intensities” reverts back to the usual display, showing the current intensity of every fixture.
Outputpreview
Live / Preview / Blind buttons
“Live” displays the usual current output of the console. “Preview” displays the intensities within the next cue (yellow bar) of the currently viewed playback. Using the up/down arrows to navigate the playback allows quick preview of upcoming cues.
Blind
“Blind” is both a visual indicator and a quick way to enter and leave “Blind Mode”.
Parameter Table
Parameter Table
At the bottom of the Output Window on the external desktops, a parameter table will open. This will show the percentages and details of all parameters of the currently selected fixtures, and fixtures that are currently in the programmer.
