Flabbe Posted November 7, 2023 Report Share Posted November 7, 2023 Hi, I actually have a FLX S48 2U and i will purchase a FLX this year. As the FLX (and also the S48) as only one ethernet connexion, i'd like to know if there is a way to do the following : - Add a Node (an Netron Obsidian EN4) to extend universes - AND add a router to have access to my tablet The problem is in the question : only one ethernet connexion on the console. Thanx for the advice and greetings from France Fabien Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 7, 2023 Report Share Posted November 7, 2023 It's a standard ethernet port so you can use a standard ethernet switch as you would with a computer network. (I'm guessing it's 100Mb/s not Gigabit). https://www.zero88.com/manuals/zeros/networking/building-a-network 1 Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 7, 2023 Report Share Posted November 7, 2023 Also worth noting that ZerOS uses "virtual NICs" (NIC = "network interface card") rather than needing multiple ethernet ports - so the single Ethernet port can have multiple IP addresses on multiple Subnets. ZerOS generally associates the IP settings to each protocol/feature, rather than to each physical NIC. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Flabbe Posted November 8, 2023 Author Report Share Posted November 8, 2023 Okay ! 🤓 Thanks guys, it really helps. I will use both node, tablet (Z monitor) and cellphone (Z remote) so it's really cool ^^ I'm not an ethernet top user, so again, thanks a lot for the tips. Have a nice day. Fabien 1 Quote Link to comment Share on other sites More sharing options...
Flabbe Posted November 8, 2023 Author Report Share Posted November 8, 2023 On 11/7/2023 at 11:09 AM, kgallen said: It's a standard ethernet port so you can use a standard ethernet switch as you would with a computer network. (I'm guessing it's 100Mb/s not Gigabit). https://www.zero88.com/manuals/zeros/networking/building-a-network I have a D-Link DGS-2000-10 and an Agora Ghost². Gigabit. Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 8, 2023 Report Share Posted November 8, 2023 7 minutes ago, Flabbe said: I have a D-Link DGS-2000-10 Looks more than capable. 1 Quote Link to comment Share on other sites More sharing options...
Flabbe Posted November 8, 2023 Author Report Share Posted November 8, 2023 Yes, just tested this afternoon. It works great. I'm doing a lot of different things in our venue (all the tasks i should say) as many of members i guess ^^ It's not easy to have time to dig deep in all manual (sound, light, video devices, etc.). So thanks again For the tips ! The workflow will be much more fluid now. Quote Link to comment Share on other sites More sharing options...
kgallen Posted November 8, 2023 Report Share Posted November 8, 2023 We didn’t do anything really! Good luck with the gig, sounds like you’re up to your neck in it! Quote Link to comment Share on other sites More sharing options...
