Question about ethernet on FLX
Hi,
I actually have a FLX S48 2U and i will purchase a FLX this year.
As the FLX (and also the S48) as only one ethernet connexion, i'd like to know if there is a way to do the following :
- Add a Node (an Netron Obsidian EN4) to extend universes
- AND add a router to have access to my tablet
The problem is in the question : only one ethernet connexion on the console.
Thanx for the advice and greetings from France
Fabien
Also worth noting that ZerOS uses "virtual NICs" (NIC = "network interface card") rather than needing multiple ethernet ports - so the single Ethernet port can have multiple IP addresses on multiple Subnets. ZerOS generally associates the IP settings to each protocol/feature, rather than to each physical NIC.
Jon Hole
Okay ! 🤓
Thanks guys, it really helps.
I will use both node, tablet (Z monitor) and cellphone (Z remote) so it's really cool ^^
I'm not an ethernet top user, so again, thanks a lot for the tips.
Have a nice day.
Fabien
  • Like 1
Yes, just tested this afternoon. It works great.
I'm doing a lot of different things in our venue (all the tasks i should say) as many of members i guess ^^ It's not easy to have time to dig deep in all manual (sound, light, video devices, etc.).
So thanks again For the tips ! The workflow will be much more fluid now.
