GLX Posted March 5, 2004 Report Posted March 5, 2004 Could a frog screen be hooked up to a fatfrog?, a diagram of where to connect the unit to the board would also be handy Quote
Paul Posted March 5, 2004 Report Posted March 5, 2004 To connect the Frog Screen to a desk, you need the SMPTE/MIDI/CAN board fitted in the desk. This board is fitted as standard in the Frog Box, and is available as an upgrade for the Leapfrog, Bullfrog and Mambo Frog. It is NOT available for Frog and Fat Frog. Quote
GLX Posted March 5, 2004 Author Report Posted March 5, 2004 Is there no way it could stuck in somehow, or is the fatfrog pcb different to the others :cry: Quote
NZ Posted March 5, 2004 Report Posted March 5, 2004 It is I believe the metal work that is different. You could probably hacksaw another hole in your desk :roll: Quote Graham
K-Nine Posted March 5, 2004 Report Posted March 5, 2004 There is also the issue of compatibility with the STMain board in the desks. As leap frogs, mambo frogs and bull frogs were added to the series later, they all have the same compatible STMain board. Some frogs/fat frogs may have earlier versions of this board, which would not be compatible with the upgrade kit. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
GLX Posted March 5, 2004 Author Report Posted March 5, 2004 How can i tell if the board is compatable :?: , drilling holes in things doesent phase me at all,you would want to see some "Gunters" that have been pulled off at shows Quote
dryoki Posted August 15, 2004 Report Posted August 15, 2004 I've read over the specs, desription, manual, and announcement, but i just wanted to get something clear. I work on a Bull Frog, but no Frog Box. But in a previous reply it was said that a smpte/midi/can upgrade kit could be used to connect the Frog Screen to a Leap Frog. I've learned not to assume, so, does that apply to the Bull Frog as well? And if so could you possibly link me to info on the upgrade kit. Basically, I am looking for a remote, so as to access the Desk from our catwalks, and as much as the Frog Box sounds like it would be great for our theater productions, the remote is more of a priority due to limited staffing during some performances. Thanks in advance. Quote
minimac Posted August 16, 2004 Report Posted August 16, 2004 A touch screen for use with the Frog Box, LeapFrog, BullFrog and Mambo Frog. this is on the frog screen product page Quote
Paul Posted August 16, 2004 Report Posted August 16, 2004 Yes you can fit the SMPTE/MIDI/CAN upgrade kit into a Bullfrog, provided it has the updated metal base tray with the extra mounting features for the kit. The update happened around October 2003. If your desk has a few extra holes on the back covered over with a metal blanking plate (not to be confused with the extra DMX sockets with plastic bungs in), then it's OK. However if your metal base tray is the older type, you'll need a new metal base tray together with some longer internal cables in order to accept the upgrade PCB. Contact our friendly service bloke Keith to discuss your options if this is the case. The part number and latest pricing for the upgrade kit can be found in the price lists on our main website: Edit: Updated link for new website. Quote
dryoki Posted August 16, 2004 Report Posted August 16, 2004 thanks to minimac and Paul for the quick response and assist. exactly the info i was looking for. Quote
