Davidmk Posted October 25, 2023 Report Posted October 25, 2023 Quick question... Is it possible to change the frame rate of the DMX outputs (without resorting to Delta transmission)?
Jon Hole Posted October 25, 2023 Report Posted October 25, 2023 Hi, No, this isn't possible currently - but it is something we've investigated previously. Can I ask why you're needing to change the frame rate? Jon Jon Hole linkedin.com/in/jonhole
Davidmk Posted October 25, 2023 Author Report Posted October 25, 2023 Because I had a fixture that responded to the house desk but not my FLX. Fixture showing "no DMX" error even though my tester said there was a signal, no errors or "flicker", with appropriate values at the fixture address. Fixture has worked with FLX many times in the past (last Sunday in particular). Anyway, after trying the house desk I reconnected the FLX and it worked on that as well. Trying a different frame rate would have been the next option. Facilities mgr reckons it's the Halloween effect (which is no more illogical). 1
