Reems2 Posted October 25, 2023 Report Posted October 25, 2023 Hi there , has anyone noticed strange behavior on the 7.14 o.s. release. On all of our 9 consoles , on starting up with the basic show for our studio’s the unpatched channel starts to blink and non the patched channel have the active-led responding. The only way to get the console working properly is to give it a factory reset and load in desired show. Blinking channel goes away and channel-active leds respond again, but after powering down and booting up, the problem re-occurs. Quote
Edward Z88 Posted October 27, 2023 Report Posted October 27, 2023 Hi @Reems2 Welcome to the forum. On 10/25/2023 at 10:41 AM, Reems2 said: on starting up with the basic show for our studio’s the unpatched channel starts to blink and non the patched channel have the active-led responding. The only way to get the console working properly is to give it a factory reset and load in desired show. Blinking channel goes away and channel-active leds respond again, but after powering down and booting up, the problem re-occurs. As discussed via email, the show file that was loaded into the consoles was partially corrupted. I have emailed you a "fixed" show file, which you should be able to load into the consoles to clear the issue. Please let me know if you have any questions. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
