Dear folks,
Using the Phantom as an off-season means of keeping up my FatFrog skills I seemed to notice the DMX outputs in the outputs-screen not responding to altered values of fixture parameters. Generics seem to work fine though. Could this be a bug :?:
grtz!
F
Which version of Phantom Frog are you using ?
I have just tried it here on my PC and the Outputs window seems to be updating the fixture parameter values OK as you adjust them with the wheels, or do you mean via other methods ?
Bran Media | Myspace
That's the 9.2.1 And yes, it happens when scrolling wheels...
how odd...
but beware, it seems that the values in the regular (desk channel) output window for fixtures are ok. However, not in the DMX-outputs...
grtz,
F
I've just had another look here, and the values in the outputs window on both the LCD on the front panel and the monitor seem to be updating and match the wheel LCD on the front panel .... how odd :?
... and the values in the outputs window on both the LCD on the front panel and the monitor seem to be updating and match the wheel LCD on the front panel...
they are indeed... But (again :wink:) not in the DMX outputs window (these are the real dmx-values sent to the fixtures (outputs-button and then '+' :wink: )
Just tried my Phantom Frog again and even in the DMX Outputs window the parameter levels appear to update correctly in the wheel LCD, Main LCD and monitor window .... curiouser and curiouser :?
Ok, just reinstalled the Phantom. Still the same 'problem'.
What I do is: select a (number of) fixture(s) using one (or more) of the 12 fixture-select-buttons. Select brightness, colour, beamshape or position. Use the wheels to alter the values.
In the meantime I look at the DMX outputs screen
And see that nothing :cry: happens...
