For Elara:
Test Mode - Faders and Rotary Controls
A Master - Sequence 2 button
B Master - Sequence 3 button
Speed Control - Memory Page button
Test Mode - Internal Tests
Internal EPROM test - Sequence 1 button
Yep - works for Mk1 & Mk2 versions of the Alcora/Elara - the software version number displayed on the LED's will vary of course because the MK 2's offered patching.
It's also worth noting that if there's an analogue output card(s) fitted then the analogue outputs will track fader movements whilst in test mode too.
Also worth adding that when testing, give the power in DIN a little waggle to see if power drops off - I've seen a few MK1's where either tracks lift on the PCB from physical movement of the desk with the PSU plugged in (back and forth to storage for example) or dry joints have developed.
I have genuine spare faders in stock for these desks, compatible PSU's for DMX only output desks, buttons/mechanisms, fader caps and knobs and some case corners (shameless plug I know but some folks assume that spares for these desks are like unicorn droppings!!)
  • Like 1
  • Thanks 1
