DALX Posted September 9, 2023 Report Posted September 9, 2023 I searched for Delete Fixture FLXS48 in ZerOS online manual and did not get a direct result. The previous option of Delete is missing when you use Setup > Select Address and you only get an UNPATCH option. I am currently using Setup > Select Address (single or column) > Unpatch > OK then select Unpatched Fixtures > Delete Key > OK to delete What am I missing please ? Quote
Jon Hole Posted September 9, 2023 Report Posted September 9, 2023 We moved the "Delete Fixture" function to Setup > Set Channel # in ZerOS 7.14 (Release Notes here - see "ZOS-11043"). We wanted clarity between "Delete" and "Unpatch" (and going into "Edit DMX Address" to delete a fixture didn't make much sense). Also, much more easily, it's possible to select the fixtures whilst in the Fixture Schedule (using the channel buttons) and press "Delete". Quote Jon Hole linkedin.com/in/jonhole
DALX Posted September 9, 2023 Author Report Posted September 9, 2023 Thanks Jon Yes it is in a better location, now to read through the release notes. Quote
Edward Z88 Posted September 11, 2023 Report Posted September 11, 2023 On 9/9/2023 at 4:19 AM, DALX said: I am currently using Setup > Select Address (single or column) > Unpatch > OK then select Unpatched Fixtures > Delete Key > OK to delete On 9/9/2023 at 10:10 AM, Jon Hole said: Also, much more easily, it's possible to select the fixtures whilst in the Fixture Schedule (using the channel buttons) and press "Delete". This procedure is described here... https://www.zero88.com/manuals/zeros/patching/fixture-schedule/deleting-fixtures Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
DALX Posted September 11, 2023 Author Report Posted September 11, 2023 I was not able to find Delete Fixture using the ZerOS Online Manual using FLXS48 as the variant , I hade to use the left hand menu Patching > Fixture Schedule > Deleting Fixtures . Patching was on the second page of search results, which had Find Out More ... Fixture Schedule which had Click To Find Out More About These Fixture Schedule Subjects ... Deleting Fixtures Thanks for the help and quick replies. Quote
