Hello! Today, I encountered an issue when adding devices. I have 4 universes on Solution XL. Universes 1 and 2 are already in use and working fine. I added new devices to universe 3, and the situation is that I have a limit of 100 addresses (100 dmx adress not working. For example 80 adress working fine). The same issue occurred with universe 4. Universes 1 and 2 have all 512 addresses in use. The firmware is up to date for last version
  • Zebroid66 changed the title to Problems with universe
This is an Elation Wi-Fi transceiver. I connected the DMX cable directly to the device, and it worked correctly. So, I identified that the issue is with the transmitter. However, today, I was thinking about how to solve it because the transmitter only allows changing Wi-Fi signal transmission addresses. But changing the addresses didn't help.
Completely by chance, I found this error on the fixtures. In the "Edit Fixtures" section, I reloaded the fixture file from the library, and everything started working.
By the way, in firmware ZerOS Version 7.13.2, I have a bug where the indicator for the fader page keeps flashing all the time.
Hi @Zebroid66
Thank you for the information.
This is an issue we are aware of on Solution consoles, caused by opening the "Panel" desktop. This issue will be fixed in the next ZerOS software update.
Please let us know if you have any questions.
Email Support
