Zebroid66 Posted September 5, 2023 Report Posted September 5, 2023 Hello! Today, I encountered an issue when adding devices. I have 4 universes on Solution XL. Universes 1 and 2 are already in use and working fine. I added new devices to universe 3, and the situation is that I have a limit of 100 addresses (100 dmx adress not working. For example 80 adress working fine). The same issue occurred with universe 4. Universes 1 and 2 have all 512 addresses in use. The firmware is up to date for last version Quote
Edward Z88 Posted September 5, 2023 Report Posted September 5, 2023 Hi @Zebroid66 Would you be able to attach a copy of your console’s show file, and confirm which type of fixture and how many of them you are attempting to patch? Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Zebroid66 Posted September 5, 2023 Author Report Posted September 5, 2023 i use elation fuze wash z350, all of are patched in screenshot files here https://www.dropbox.com/scl/fo/re8db33mdrhel5mtgzvjn/h?rlkey=h7tdok73o04ooaxfkl9sfa4v6&dl=0 Quote
Zebroid66 Posted September 5, 2023 Author Report Posted September 5, 2023 I found the problem, and it lies in my Wi-Fi signal transmitter. 1 Quote
Edward Z88 Posted September 6, 2023 Report Posted September 6, 2023 Hi @Zebroid66 19 hours ago, Zebroid66 said: I found the problem, and it lies in my Wi-Fi signal transmitter. Thank you for the update. Out of interest, what transmitter are you using? How have you solved the issue? Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Zebroid66 Posted September 6, 2023 Author Report Posted September 6, 2023 This is an Elation Wi-Fi transceiver. I connected the DMX cable directly to the device, and it worked correctly. So, I identified that the issue is with the transmitter. However, today, I was thinking about how to solve it because the transmitter only allows changing Wi-Fi signal transmission addresses. But changing the addresses didn't help. Completely by chance, I found this error on the fixtures. In the "Edit Fixtures" section, I reloaded the fixture file from the library, and everything started working. By the way, in firmware ZerOS Version 7.13.2, I have a bug where the indicator for the fader page keeps flashing all the time. Quote
Edward Z88 Posted September 7, 2023 Report Posted September 7, 2023 Hi @Zebroid66 Thank you for the information. 20 hours ago, Zebroid66 said: By the way, in firmware ZerOS Version 7.13.2, I have a bug where the indicator for the fader page keeps flashing all the time. This is an issue we are aware of on Solution consoles, caused by opening the "Panel" desktop. This issue will be fixed in the next ZerOS software update. Please let us know if you have any questions. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
