Matching a chase to music
lugamil
Hi all,
I was wondering if it is possible to match a chase, cue or effect to music. I found some topics asking similar questions but most are years old and much has changed since.
I'm pretty sure the FLX S-series does not support this on a hardware level (maybe it could be done with one of the ports?).
With the last update however, OSC was introduced which I believe could make this possible with an external device.
I've never used OSC before. Would this be possible and how? Has anyone tried/done this?
Can't wait to hear your thoughts.
Regards
Mil
Hi Mil,
FLX S consoles do not have Sound-to-Light functionality, so there is no way of automating a chase to follow the beat of an audio track.
When a chase is programmed on a playback, the playback's button automatically becomes a Tap Tempo, allowing you tap the playback's button to synchronise the chase to a beat.
You could program a sequence of cues on a playback. Theoretically, you could then send repeated OSC GO messages to trigger the cues on this particular playback one after the other, essentially resulting in the cue stack on the playback behaving as a chase. To do this you would need to come up with a way of a software package taking an audio track, and then repeatedly sending a particular OSC message on each beat.
Alternatively, you could use more of a "timecoded" approach, where you start an audio track in a software package, and automatically at certain points in the track the software package sends OSC messages to FLX S, which then trigger certain cues at different points in the song.
Hope this helps,
Email Support
Hi Edward
I currently use this a lot. It does what I want most of the time but I've been in situations where there's a DJ or something before or after the show I'm doing. When the DJ or whatever is playing I don't need my entire package but some lights is always a plus. Right now I have some chases using global tap tempo for these situations so if the speed of the lights has to be adjusted it is easy. Still, it would be better if the speed could be set automatiscally.
In the example above, the timecoded approach obviously wouldn't work. I don't know what the DJ will do.
Using OSC, is it possible to send a GO/NEXT signal to a fader which is set to global tap tempo to set the global tap tempo?
Either way I think i'll try some things out with a Raspberry PI and see what happens.
Regards
Mil
Hi Mil,
Correct - based on your original description I wasn't sure whether you were looking to sync to an audio track or live music.
It is not possible to trigger a Global Tap Tempo playback over OSC.
It is possible to send a Playback Go x message, where x is the playback you wish to trigger. Each time this command is sent you would step through each cue on playback x.
If you sent these commands to a chase that was running, you would end up with a mixture of the chase automatically running using Tap Tempo, and jumping cues when OSC GO messages are received.
I hope this makes sense.
Email Support
  • 5 months later...
Hi Edward Z88,
I have an Zero 88 FLX S24.
I assume you didnt integrate the osc /beat/tap endpoint?
Is it planned to integrate this endpoint with an future version?
If not, is it possible to use the playback/next endpoint vor a variable chase, or does this only work with an explizit named chase?
Thanks
Lazer
There are currently no plans to implement a dedicated way of triggering the console's Global Tap Tempo remotely via OSC.
What you could do, is record your different lighting states into a playback. Then, rather than converting the playback into a Chase, leave it as a Cue Stack. Then, you could send the console a Playback x GO message over OSC each time there's a "beat", to advance through the lighting states on the playback in time with a beat.
Please let us know if you have any questions.
Email Support
