charliez Posted July 16, 2023 Report Posted July 16, 2023 we have a problem with the zero 88 solution console, there are some output stays can not be cleared. Please refer to the attached picture. if you zero the grand master, the output will also be zero. i do not know where are those output come from. Advice will be appreciated. Charlie Quote
Jon Hole Posted July 16, 2023 Report Posted July 16, 2023 On 7/16/2023 at 12:39 PM, charliez said: i do not know where are those output come from. Expand If you click that “Source” button at the top, ZerOS will tell you. Quote Jon Hole linkedin.com/in/jonhole
Jon Hole Posted July 16, 2023 Report Posted July 16, 2023 (Also, worth noting that you're using quite old software by the looks of it - you can update here: https://www.vari-lite.com/global/products/zeros-software) Quote Jon Hole linkedin.com/in/jonhole
Edward Z88 Posted July 16, 2023 Report Posted July 16, 2023 Click the link below for information on the Output Window, including the "Source" button, and the colour coding... https://www.zero88.com/manuals/zeros/desktops-windows/output-window Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
iank99 Posted July 17, 2023 Report Posted July 17, 2023 It's also worth noting - it looks like your desk might have some dirty faders, the values shown are what I typically see when servicing Solutions/LeapFrogs & so on. It's a relatively easy job to do unless faders need replacing - Servisol Super10 is the 'go to' fluid but don't use much per fader Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
