scottydog75 Posted June 26, 2023 Report Posted June 26, 2023 (edited) Anyone got some good hints for manipulating the FLX Encoders when using Phantom ZerOS? I often struggle to understand how these are supposed to be used with a mouse (or is there some secret keyboard snytax?) - perhaps someone can enlighten me! 😅 Thanks Alex Edited June 27, 2023 by scottydog75 Typo Quote
Edward Z88 Posted June 26, 2023 Report Posted June 26, 2023 Hi Alex, Click and hold on an encoder. Entirely horizontal dragging then provides coarse control. If you drag diagonally left/right, this will provide finer control. If you hold SHIFT, and then click on a parameter's name on the internal touchscreen, you can then type @ followed by a percentage, followed by ENTER, to take the parameter to that percentage. Hope this helps. Quote Edward Smith Formerly: Zero 88 Product Specialist -Â Email Support Currently: Obsidian Control Systems Product Specialist
scottydog75 Posted June 26, 2023 Author Report Posted June 26, 2023 Perfect thanks! Like a dunce I was trying to 'turn' the encoders with my cursor - that will explain the odd control I was experiencing! Quote
Davidmk Posted June 27, 2023 Report Posted June 27, 2023 3 hours ago, scottydog75 said: a dunce I was trying to 'turn' the encoders with my cursor - You are not alone. Been there, done that, got the tee shirt. 😀 2 Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
