DALX Posted May 24, 2023 Report Posted May 24, 2023 Can you determine what channel mode a fixture is patched at ? It is easy to determine if there are several patched by looking at the Address in Fixture Schedule, but it is not obvious if it is the last fixture, unless I patch something after it to see the Addresses. Quote
Edward Z88 Posted May 24, 2023 Report Posted May 24, 2023 Hi @DALX 12 minutes ago, DALX said: Can you determine what channel mode a fixture is patched at ? In the Fixture Schedule, tap on the fixture in the "Change All Fixtures / Modes" column. The current mode will then be highlighted. Click Cancel to close. Hope this helps. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
DALX Posted May 24, 2023 Author Report Posted May 24, 2023 Thank you Edward, it certainly does help. I tried searching for this but did not find a direct answer, so I have a word document to keep track of these useful snippets. 1 Quote
Edward Z88 Posted May 24, 2023 Report Posted May 24, 2023 46 minutes ago, DALX said: Thank you Edward, it certainly does help. I tried searching for this but did not find a direct answer, so I have a word document to keep track of these useful snippets. I've added this tip here... https://www.zero88.com/manuals/zeros/patching/fixture-schedule Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
