DALX Posted May 24, 2023 Report Share Posted May 24, 2023 Can you determine what channel mode a fixture is patched at ? It is easy to determine if there are several patched by looking at the Address in Fixture Schedule, but it is not obvious if it is the last fixture, unless I patch something after it to see the Addresses. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 24, 2023 Report Share Posted May 24, 2023 Hi @DALX 12 minutes ago, DALX said: Can you determine what channel mode a fixture is patched at ? In the Fixture Schedule, tap on the fixture in the "Change All Fixtures / Modes" column. The current mode will then be highlighted. Click Cancel to close. Hope this helps. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
DALX Posted May 24, 2023 Author Report Share Posted May 24, 2023 Thank you Edward, it certainly does help. I tried searching for this but did not find a direct answer, so I have a word document to keep track of these useful snippets. 1 Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 24, 2023 Report Share Posted May 24, 2023 46 minutes ago, DALX said: Thank you Edward, it certainly does help. I tried searching for this but did not find a direct answer, so I have a word document to keep track of these useful snippets. I've added this tip here... https://www.zero88.com/manuals/zeros/patching/fixture-schedule Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
DALX Posted May 25, 2023 Author Report Share Posted May 25, 2023 Very useful thank you Edward. 1 Quote Link to comment Share on other sites More sharing options...
