simzee47 Posted May 23, 2023 Report Share Posted May 23, 2023 Hi All, Our FLX 48S desk has only 1 Universe. Before the latest update there was a way of using the Universe outputs as a DMX splitter which I had set via instructions from this forum. I used the 5 pin output to feed the dimmer rack and the 3 pin to run on-stage fixtures and all worked fine. Since the update I don't seem to be able to do this. I tried changing the Output of Universe 2 to Output 1 but it says this is already being used by Universe 1. Is the feature I had used before been removed from the latest software release? Dave Quote Link to comment Share on other sites More sharing options...
kgallen Posted May 23, 2023 Report Share Posted May 23, 2023 You will have to remove Output 2 from Universe 2 first. Then use Add in Universe 1 to add Output 2. In fact the limitation is on number of DMX addresses so if you have a 1 universe console you have a 512 DMX address limit and you could spread those anywhere across 64 universes (silly I realise). So you could use Output 1 with Universe 1 and Output 2 with Universe 2 if you wanted so long as you didn't have more than 512 DMX addresses patched across both Universes. What you want to do is usually what I do - 1 universe output over two connectors - 1 output to the dimmers and 1 output to the DMX chain around the LED fixtures. Â After a desk reset, Universe 2 will have Output 2 assigned: Â Click on "Output 2". Then click Remove on this screen: Â Universe 2 will end up looking like this: Â In Universe 1, click Add then type 2 to add Output 2 to Universe 1: Â 1 1 Quote Link to comment Share on other sites More sharing options...
simzee47 Posted May 24, 2023 Author Report Share Posted May 24, 2023 Many Thanks. When I got home from the Theatre yesterday I thought about it and realised what I hadn't tried which is exactly what you've described. I'm on it.😀 Quote Link to comment Share on other sites More sharing options...
