Hi,
im using FLX S24.
I have a scene lit, and I want to use playback flash but to momentarily broadcast a new scene, which is a mixture of new (higher intensity) lights, but also zeroing other lights to intensify the momentary flash. Something to do with priorities?
Help!
many thanks, Dave
Hi Dave,
14 hours ago, Zulu said:
Ed, I tried this…. Perfect! Exactly what I was looking for.
Brilliant - pleased to hear it.
It is possible to configure playback buttons, so that they solo when pressed, rather than flash. This means you don't have to hold the Z/SHIFT key to access solo.
To set a playback's button to solo, hold SETUP and tap the playback button you wish to configure. Then from the Button Function options at the bottom, choose Solo.
Hope this helps,
