im using FLX S24.
I have a scene lit, and I want to use playback flash but to momentarily broadcast a new scene, which is a mixture of new (higher intensity) lights, but also zeroing other lights to intensify the momentary flash. Something to do with priorities?
Help!
many thanks, Dave
Hi Dave,
  On 5/17/2023 at 5:14 PM, Zulu said:
Ed, I tried this…. Perfect! Exactly what I was looking for.
Expand
Brilliant - pleased to hear it.
It is possible to configure playback buttons, so that they solo when pressed, rather than flash. This means you don't have to hold the Z/SHIFT key to access solo.
To set a playback's button to solo, hold SETUP and tap the playback button you wish to configure. Then from the Button Function options at the bottom, choose Solo.
Hope this helps,
