Jouper Posted May 11, 2023 Report Posted May 11, 2023 How can i set the values when my cue fader is for example at 0. So for example i want my cue level from 0 to 100 to have the intensity of my fixture be 30 to 90 Quote
Edward Z88 Posted May 11, 2023 Report Posted May 11, 2023 Hi @Jouper 2 hours ago, Jouper said: So for example i want my cue level from 0 to 100 to have the intensity of my fixture be 30 to 90 If when you lower a playback fader, you want your fixtures to stay on @ 30%, you could program another playback with your fixtures recorded @ 30%. Then, you can raise this playback fader to full, and leave it. With this playback up, the lowest value that these fixtures can then be taken to by your cues is 30%. I hope this achieves what you're after. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted May 11, 2023 Report Posted May 11, 2023 Then a Topset for the 90%? Depends on the console... Quote
Jouper Posted May 11, 2023 Author Report Posted May 11, 2023 3 hours ago, Edward Z88 said: Hi @Jouper If when you lower a playback fader, you want your fixtures to stay on @ 30%, you could program another playback with your fixtures recorded @ 30%. Then, you can raise this playback fader to full, and leave it. With this playback up, the lowest value that these fixtures can then be taken to by your cues is 30%. I hope this achieves what you're after. OK, so there is no other way like setting a playback specific default value, right? Quote
Edward Z88 Posted May 12, 2023 Report Posted May 12, 2023 15 hours ago, Jouper said: OK, so there is no other way like setting a playback specific default value, right? There is no way of setting a playback "minimum" level. The playback fader will take the intensity level of the current cue down to 0%. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
