emilie Posted May 10, 2023 Report Posted May 10, 2023 (edited) HI Is it possible to support the Lumenradio CRM Nova TX on an FLX S48? I try but it doesn't work I'm on the software 7.13 I don't understand why. I also have a problem with ethernet I would like to change the IP adress, but i can't thank you for your attention Emilie Edited May 10, 2023 by Edward Z88 Formatting issues. Quote
Edward Z88 Posted May 10, 2023 Report Posted May 10, 2023 Hi @emilie Welcome to the Zero 88 Forum. 30 minutes ago, emilie said: Is it possible to support the Lumenradio CRM Nova TX on an FLX S48? The LumenRadio CRMX Nova TX is a single universe wireless DMX transmitter, with no Ethernet functionality... https://lumenradio.com/products/crmx-nova-tx/ You can therefore plug the DMX output from the console into the CRMX Nova TX's DMX input, to transmit the universe wirelessly. If your device has an Ethernet port, please could you link to the product's webpage, so we know exactly which unit you have? 32 minutes ago, emilie said: I also have a problem with ethernet I would like to change the IP adress, but i can't What network protocol are you trying to use? Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
