HenryYandell Posted May 4, 2023 Report Posted May 4, 2023 Hi there! I have 6 Martin Rush 2 RGBW zoom fixtures arranged in a 2x3 grid and assigned to MFKs. What’s the best way to set up a twinkling/flickering effect (kind of like what happens to the Eiffel Tower at midnight I suppose?), Would I use a chase or is there a different better way? Quote
kgallen Posted May 5, 2023 Report Posted May 5, 2023 I would use the Effect section. Choose ‘lightning’, wind up the speed and set the offset to random. 1 Quote
Edward Z88 Posted May 5, 2023 Report Posted May 5, 2023 11 hours ago, HenryYandell said: Hi there! I have 6 Martin Rush 2 RGBW zoom fixtures arranged in a 2x3 grid and assigned to MFKs. What’s the best way to set up a twinkling/flickering effect (kind of like what happens to the Eiffel Tower at midnight I suppose?), Would I use a chase or is there a different better way? You could also select the fixtures, and try the Candle effect (Effect 9). If this doesn't give what you're after, try Effect 4 (Chaser 1/8), but reduce the effect "Size" down using the encoders, and increase the "Speed". Hope this helps. 1 Quote Edward Smith Product Specialist Email Support
