DRP Posted April 12, 2023 Report Share Posted April 12, 2023 Recent show seemed perfect for using Groups: 2 halves of stage lit independently at 2 different levels each i.e. Left High, left Low, and same for Right. Set up as 4 separate groups (with intensities), made creating the cue stack so easy. (Other one-off cues as well, but these covered a high percentage of the stack). Then came the problem. I wanted to add an extra lantern to Left High Group. Chose a Left High cue, added the extra lantern at desired intensity. So now I need to update the Group. Selected all the lanterns in that Group, touched UPDATE, touched Group. Should that have worked? Or did I (wrongly) double tap group, turn intensities off, and then try to set them again? Either way, results were garbage - random intensities seemed to appear whenever group was used. Couldn't find a way to reset that group, ended up setting each of the relevant cues manually!! Much frustration. I'm sure this is a tale of my idiocy, but I'd appreciate it very much if you would confirm the steps for adding a new fixture, with intensity, to an existing Group! Many thanks. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 12, 2023 Report Share Posted April 12, 2023 Hi @DRP 4 hours ago, DRP said: I'd appreciate it very much if you would confirm the steps for adding a new fixture, with intensity, to an existing Group! To update a group, first ensure no cues are running, and the CLEAR button is off. Then, you can double tap the group to see it outputting, make your changes such as adding in a new light, and then ensure all the fixtures you wish to include in the group are selected. Then tap UPDATE, and tap the group. This is similar logic to updating a cue - output it first so you can see it, make your changes, and then update it. If you add a new light in to a group, this will not automatically add the new light into cues that were programmed using the group. Let us know if you have any questions. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
