thierry Posted March 28, 2023 Report Posted March 28, 2023 Hi everyone, I have some Linear Led, when i choose a color available in the standar color palette (cause the button is blue) everything is fine, it's also good with the picker an the fader buttons, but when i want a color from Lee/Rosco/Gamecolor... and all the other options (and the colors are available cause all buttons are blue and not grey) then it's not working. i'm running 7.13 and before all was working fine. Perhaps an issue with my fixture configuration (because the fixtures are not part of the official library, i've created them), and i should better send you the informations so that you create the fixture library better then i did... ? Regards, Thierry Quote
Jon Hole Posted March 28, 2023 Report Posted March 28, 2023 Hi Thierry, Can you share your showfile please so we can take a look? Jon Quote Jon Hole linkedin.com/in/jonhole
thierry Posted March 28, 2023 Author Report Posted March 28, 2023 Hi Jon, Actually i can't, i send you all tomorrow morning. Regards, Thierry Quote
thierry Posted March 29, 2023 Author Report Posted March 29, 2023 Good Morning, As requested, my showfile... (wow, sounds like an Elvis Presley's "Soundboard"...) Regards, Thierry SHOW 29-03-2023.zos Quote
Jon Hole Posted March 29, 2023 Report Posted March 29, 2023 Thanks for sharing Thierry. Sorry you're seeing this issue. There's nothing I can see that's causing an issue, so I've passed this onto the software team to review (reference ZOS-11458). Jon Quote Jon Hole linkedin.com/in/jonhole
thierry Posted March 29, 2023 Author Report Posted March 29, 2023 Ok, if necessary, i can send you the manual of the Linear Led, cause perhaps there is something wrong in the way we've created them with the fixture editor, and i'm sure you know better then me how to do it correctly. Thierry Quote
Jon Hole Posted March 29, 2023 Report Posted March 29, 2023 58 minutes ago, thierry said: Ok, if necessary, i can send you the manual of the Linear Led, cause perhaps there is something wrong in the way we've created them with the fixture editor, and i'm sure you know better then me how to do it correctly. If ZerOS was outputting the values we expected, but the fixture wasn't responding correctly, that would be helpful... however, in this situation, ZerOS isn't outputting the values we'd expect when you select a Colour Filter so, at this stage, we don't need the manual - but thank you. Quote Jon Hole linkedin.com/in/jonhole
thierry Posted March 31, 2023 Author Report Posted March 31, 2023 Hi, I've found a fixture profile (generic LED IRGBWS) which is working well with my LinearLed. But now my memories are wrong because the default setup for the LinearLed is 0% for the color attributes, and the the new profile is 100% per attributes. I don't want to record again all my memories, so i would like to know if there is an option to edit the profile. Where can i find the GFT v40.ift library to import with the toolt editor the profile i need and reset it to 0% (rgbw) ? I've also tried to change the default values with the desk but with no success. Quote
thierry Posted March 31, 2023 Author Report Posted March 31, 2023 Finally it was my fault, i must have done something wrong, but now it's ok, new profile IRGBWS loaded and then default attributes changed into 0% all, so that my old memories can live a little bit more. But a question remains, is there any way to manage the library with the tool editor and Windows, like we used to do with the old "ift" format ? Quote
Edward Z88 Posted March 31, 2023 Report Posted March 31, 2023 Hi Thierry, 8 hours ago, thierry said: But a question remains, is there any way to manage the library with the tool editor and Windows, like we used to do with the old "ift" format ? The fixtures in the library cannot be edited. For information on editing fixture defaults, please see the link below... https://www.zero88.com/manuals/zeros/controlling-fixtures/defaults Hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
