DALX Posted March 27, 2023 Report Share Posted March 27, 2023 I have used the eDMX4 Configuration utility to set my eDMX4 PRO IP Address to 192.168.0.1, Subnet Mask to 255.255.0.0, which is my FLXS48 settings, Default Gateway to 192.168.0.1 , then connected the eDMX4 PRO to my FLXS48 network port. In Setup > Universes > IP Address I have set Static IP Address. I have patched a device to universes 1, 2, 3 and 4 in Art-Net 4 settings, but I do not have any data to my eDMX4 PRO yet and none of the four port led's are lit. Any suggestions on what step I have missed out please ? eDMX4 PRO User Manual (EN).pdf Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted March 27, 2023 Report Share Posted March 27, 2023 15 minutes ago, DALX said: I have ... set my eDMX4 PRO IP Address to ... my FLXS48 settings You can't have two IP addresses the same on the network... you need two unique IP addresses, but that are within the same subnet. So, for example 192.168.0.1 and 192.168.0.2 Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
