Franck Lombard Posted March 20, 2023 Report Share Posted March 20, 2023 Good morning, I have a Frog STMain1. The battery was dead. The console wouldn't start. After changing the battery (ni-mh 150 mah), the system starts by directly requesting a system update. I had already changed the floppy drive to a USB adapter. It works because it allowed me to successfully update to 10.12. But today there is a problem. It downloads the update (100%), then reads it (100%), then announces "this disk is for a frog series desk only..." It does not work with the update that worked 2 years ago, nor the one downloaded from the site today. Same version 10.12 for the 2 tests. Issues : - Does the STMain1 bios directly accept 10.12 after a total loss of the system? Or should I start by installing an earlier version (9.2 for example.. but impossible to find on the net!) - Has the low battery corrupted something (rom???) FYI: impossible to give you a serial number but on the motherboard, the control labels indicate "MAR 02" and on the ICs "Program D603" and "Program C404". I found a photo before the 10.12 update: bios Version 1.0.1 4/4/2001 and Software Version 5.0.1 21/2/2002 Thank you. Quote Link to comment Share on other sites More sharing options...
KWR88 Posted March 21, 2023 Report Share Posted March 21, 2023 Hi Franck, Have replied to you PM this morning. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
