Davidmk Posted March 12, 2023 Report Posted March 12, 2023 What's with the "8fpn12" and "Hhpn12" in the attached image? I'm getting these (apparently) extraneous characters whenever I put a single or - as here - double cue-trigger in the macros field. The playback(s) & cue(s) do exist and they are named. Quote
Edward Z88 Posted March 14, 2023 Report Posted March 14, 2023 On 3/12/2023 at 11:13 AM, Davidmk said: What's with the "8fpn12" and "Hhpn12" in the attached image? Expand Good question. This is what I see when creating this macro... On 3/12/2023 at 11:13 AM, Davidmk said: I'm getting these (apparently) extraneous characters whenever I put a single or - as here - double cue-trigger in the macros field. Expand If you click OK, and then click "Advanced" again, do you still see these erroneous values? Would you be able to share a copy of your show file? I'll then investigate further. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted March 14, 2023 Author Report Posted March 14, 2023 Welcome back, hope you've had a good holiday. I see them consistently although the actual characters vary. My showfile is a bit of a work in progress but based on one I've been using for a long time on this and my other desk and across more than one version of ZerOS. It has a lot (127) of cues triggering other cues or releasing playbacks. Not sure when it started or on which desk. I'll try and send it tonight but before I do I'll do some checking on older versions, maybe even the other desk. Quote
Edward Z88 Posted March 14, 2023 Report Posted March 14, 2023 Hi David, On 3/14/2023 at 4:04 PM, Davidmk said: Welcome back, hope you've had a good holiday. Expand Very nice thank you! On 3/14/2023 at 4:04 PM, Davidmk said: I see them consistently although the actual characters vary. My showfile is a bit of a work in progress but based on one I've been using for a long time on this and my other desk and across more than one version of ZerOS. It has a lot (127) of cues triggering other cues or releasing playbacks. Not sure when it started or on which desk. I'll try and send it tonight but before I do I'll do some checking on older versions, maybe even the other desk. Expand Thanks for the information. Will look out for the show file. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted March 14, 2023 Report Posted March 14, 2023 On 3/14/2023 at 4:39 PM, Edward Z88 said: Very nice thank you! Expand What is this "holiday" thing you speak of? Welcome back to the madness! 2 Quote
Davidmk Posted March 14, 2023 Author Report Posted March 14, 2023 3 mails sent to support with attachments. Ignore the first one - sent in error with bits missing. 1 Quote
Davidmk Posted March 15, 2023 Author Report Posted March 15, 2023 For the benefit of the community... Edward has taken a look at this and it turns out it is confined to consoles (phantom ZerOS doesn't have the issue). It has been logged on the system to allow the software team to investigate. Initially, this is at a low priority which is fair enough as it doesn't cause any actual harm. Whilst looking at old show files and collecting screen shots to help with this I discovered something else which is worth knowing. I loaded an old file but forgot which so I went into save to check and found it had a different name. I asked Edward about this and it turns out show files contain their original names and these are used as the default when you save them. This means that, if you change the file name (in Windows for example) then it will revert to the original name when loaded into the desk. @Edward Z88 is truly the fount of all ZerOS knowledge. Just wish I could copy & paste from his brain to mine😀 1 Quote
