Pascal Posted March 7, 2023 Report Posted March 7, 2023 Hi, Not sure if this has already been reported... I noticed a bug with the FLX-S48 console (7.13 version), and probably with other FLX consoles : In fader functions, when I select "manual fade (one-way)" or manual fade (two-way)" the new parameter works fine, but when I try to revert back to its initial state ("HTP master" for example), the behavior remains as it is, and doesn't go back. The only way I found to change the setting again is to turn the console off and on. The same is happening with phantom zeros 7.13 running on my PC. maybe this will be fixed in the next update 🤞 best regards Pascal S. Quote
Edward Z88 Posted March 7, 2023 Report Posted March 7, 2023 Hi @Pascal 44 minutes ago, Pascal said: Not sure if this has already been reported... I noticed a bug with the FLX-S48 console (7.13 version), and probably with other FLX consoles : In fader functions, when I select "manual fade (one-way)" or manual fade (two-way)" the new parameter works fine, but when I try to revert back to its initial state ("HTP master" for example), the behavior remains as it is, and doesn't go back. The only way I found to change the setting again is to turn the console off and on. The same is happening with phantom zeros 7.13 running on my PC. Thank you for your description of the issue. This is an issue we are aware of, and is logged as reference number ZOS-8363 on our system. This issue will be fixed in the next software update. If you have any questions, please let us know. Edward 1 Quote Edward Smith Product Specialist Email Support
