frEd Koniec Posted March 1, 2023 Report Share Posted March 1, 2023 Hi I'm trying to connect a Capture 2022 Student Edition project to Phantom zerOS 7.13. Network overview on Phantom says "transmitting on 127.0.0.1" Capture says " project console link : FLXS48 Phantom 127.0.0.1 " but there is still no link between the two softwares... I think it could be solved in patch sections of both softs but all my tries were unsuccessful thanks for your help regards Fred Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 1, 2023 Report Share Posted March 1, 2023 Hi @frEd Koniec Welcome to the Zero 88 Forum. 37 minutes ago, frEd Koniec said: Network overview on Phantom says "transmitting on 127.0.0.1" Capture says " project console link : FLXS48 Phantom 127.0.0.1 " This suggests that Capture and Phantom ZerOS are talking to one another. 42 minutes ago, frEd Koniec said: I think it could be solved in patch sections of both softs but all my tries were unsuccessful By default, if you patch on universe 1 in ZerOS, this will be controlling the first universe in Capture. To check this configuration hasn't been changed in ZerOS, go to Setup -> Universes, and in the CITP section choose Reset To Defaults -> Start at CITP Universe 0. In Capture, fixtures can be given a "Channel" number and a "Patch" number. The "Channel" number is the same as the ZerOS "Fixture" number. The "Patch" number is the same as the ZerOS "Address" number. If you select fixture 1 in ZerOS, this should select "channel" 1 in Capture. Do you see the fixture highlight in Capture when you select it in ZerOS? I hope this helps. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
frEd Koniec Posted March 1, 2023 Author Report Share Posted March 1, 2023 Hi Edwards thanks for your answer I've tried but it still doesn't work Should I patch all the fixtures manualy into the console? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 1, 2023 Report Share Posted March 1, 2023 Hi @frEd Koniec 37 minutes ago, frEd Koniec said: Should I patch all the fixtures manualy into the console? Yes - the patch in ZerOS must match the patch in Capture, just as if you were patching your show in a real venue. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
frEd Koniec Posted March 1, 2023 Author Report Share Posted March 1, 2023 Well... thanks and sorry for the time lost indeed I've to patch my console of course it works quite well now I though Capture and zerOS would make a kind of "emulation" that transfer the patch from one to the other Ed, thanks for your support and tutos have a nice evening FRED Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 1, 2023 Report Share Posted March 1, 2023 Hi Fred, No problem at all. If there's anything else we can help with, please let us know. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
