connectivity Capture 2022 Student Edition with Phantom zerOS 7.13
frEd Koniec
Hi
I'm trying to connect a Capture 2022 Student Edition project to Phantom zerOS 7.13.
Network overview on Phantom says "transmitting on 127.0.0.1"
Capture says " project console link : FLXS48 Phantom 127.0.0.1 "
but there is still no link between the two softwares...
I think it could be solved in patch sections of both softs but all my tries were unsuccessful
thanks for your help
regards
Fred
Hi @frEd Koniec
Welcome to the Zero 88 Forum.
This suggests that Capture and Phantom ZerOS are talking to one another.
By default, if you patch on universe 1 in ZerOS, this will be controlling the first universe in Capture. To check this configuration hasn't been changed in ZerOS, go to Setup -> Universes, and in the CITP section choose Reset To Defaults -> Start at CITP Universe 0.
In Capture, fixtures can be given a "Channel" number and a "Patch" number. The "Channel" number is the same as the ZerOS "Fixture" number. The "Patch" number is the same as the ZerOS "Address" number.
If you select fixture 1 in ZerOS, this should select "channel" 1 in Capture. Do you see the fixture highlight in Capture when you select it in ZerOS?
I hope this helps.
Email Support
Well...
thanks
and sorry for the time lost
indeed I've to patch my console    of course
it works quite well now
I though Capture and zerOS would make a kind of "emulation" that transfer the patch from one to the other
Ed, thanks for your support and tutos
have a nice evening
FRED
