Hi - I'm trying to record a new group on a Phantom FlxS24, but when I press the record button - I get the cue record window rather than the group record window - any idea what I'm doing wrong?
Hi Jon, thanks for responding- when I press record the screen flicks to the record options screen, there is no way to select an empty group.
The group window prior to the pressing of record has no empty groups on it, just the button labelled ‘create automatic groups’.
Hi @Ian_p
By default, the Record Options window should only appear on the internal touchscreen if the RECORD key is pressed and held. It therefore sounds like a setting may have been changed on your console. This setting lives in SETUP -> Settings -> Record & Update. The default option is "External Display", meaning the Record Options will appear on external desktops (such as remote apps) when RECORD is tapped, but will only appear on the internal touchscreen when pressed and held. When set to "External Display", you should be able to record groups as expected.
I hope this helps.
Product Specialist
Email Support
