alg Posted February 16, 2023 Report Posted February 16, 2023 We have a Jester 48. The Page A button LED is now permanently flashing. Depending on mode it can still select either 1-24 or 25-48. In most respects it still seems to work as expected, however in Run Mode we are no longer able to Flash individual channels. The Page B button still works to flash Sub Masters and the LEDÂ is not flashing. The handbook under "Presets in Run Mode" indicates we should still be able to Flash channels on Preset A. You can still raise channels on the fader as expected. I have been unable to determine if this propblem is due to a setting being wrong somewhere in the desk or if the desk has developed a fault. Advice please. Quote
Jon Hole Posted February 16, 2023 Report Posted February 16, 2023 It's been awhile - I had to open the manual! Take a look at page 27 & 28, especially the end of Page 28: https://www.vari-lite.com/b-dam/vari-lite/discontinued-products/jester/english/jester-manual-3-4.pdf Quote Jon Hole Global Product Manager, Systems and Control
alg Posted February 20, 2023 Author Report Posted February 20, 2023 Problem solved, all good, thanks for your help. Slight mystery as to how this function was engaged as we never use Auxiliaries! 1 Quote
