So today I was a muppet and left 2 playbacks that control the fog and fan on our haze machine on while programming 2/3 of a show.
First I thought I'd just go back to the start, lower the playbacks, record tracking forwards and that would sort it, but then I remembered I had altered the playbacks throughout the show.
So what I have done is unpatched it then repatched, I then ran through some cues and it seems to have gone. Would this have worked?
If you mean deleted the fixture, and then repatched it, then yes - that would work.
If you simply removed the DMX address from it, and then added a DMX address again, no - the data would still be intact.
Jon Hole
Yeah I went into setup, deleted the fixture that added it again albeit on the same address, firstly to see if that would work, I was going to add it back on a different address but adding it back on the same address seemed to work.
Thanks
